1 - 8 of 8 Posts
So A month ago I replace my head gaskets (first time I have done anything like that) and after putting at all back together, I can't get it to start. I don't think my valves are to tight. I set the timing all the way advanced and get exhaust backfire. when I go about 5deg towards retard, I get carb backfire (cool fire though, great way to get a haircut. maybe I'll start a business 'Cougar Crew Cuts, shorter hair in under 30 seconds', but I digress :D ). Does this sound like a leaky intake manifold? Or maybe something else.
Sounds like...
Without a little more info, sounds like need to do more adjustment on the ignition timeing...:D
shane
Super Moderator
Sounds to me like the distributor is installed 180 degrees out.
Yeah....... yeah, man - that's exactly what it sounds like to me also. BTW - about 13 years ago, I had most of the hair on one side of my head burned back to about 1/4 of an inch long using this method. Also burned the side of my face pretty well, so be careful.....
Lab Rat
Discussion Starter · #5 ·
I'll check again. #1 to TDC with both valves close and dist. should point to #1 wire, right. I'll give it a look tonight and let you know.
Thanks guys
Discussion Starter · #7 ·
Once again you guys are dead on, thanks a bunch, my cat lives !!!
Glad to hear it! Now if I could only get mine to run...... of course, I guess that means I'd have to put it back together first;)
Lab Rat
1 - 8 of 8 Posts
