My roomate bought these heads for his '73 Bronco w/ a 302 -2v. The guy told him they would bolt right up - but he has concerns. These heads look to be physically bigger than the ones he has on now (stock), and have a different bolt pattern (valve cover). My questions are...
1. Can someone tell me what year/engine size these orginally came on.
2. Will these work on a stock '73 302-2v
please see photos below. I took pics of all of the numbers I could find - I didnt see a "standard casting number" anywhere. *shrug*
ANY help is appreciated.
Let me know if additional pics are needed to reveal the identity.
*NOTE* the number on the first pic is 9A10 the other head is 9A11
The casting numbar is the E7TE. meaning they are 87 engenering heads for a truck. The 9A** is the casting dates. one on Jan 10th and the other is Jan 11 1989. The valve covers should be the same as far as I know. Can you get a picture of his old motor? neal.
Super Moderator
The casting ID number is shown in one of your pictures.
E= Decade, 1980's
7= Year of that decade = 1987
T = Truck application (design)
This head would be a poor choice for a replacement for your friend's Bronco. It uses the bolt and sled fulcrum to attach rocker arms, the '73 Bronco 302 used a stud and ball mount. Your friend needs to find a head with casting ID of D0__ or D1__ or D2__. There are also wonderful aftermarket heads available from Edelbrock, World Products, Air Flow Research and many other companies.
I don't understand your comment about valve cover bolt pattern, it is the same on the heads in your pictures as any 302 except the 69 - 70 Boss.
Royce Peterson
