1 - 13 of 13 Posts
Now that the Petronix is all straightened out I ran into an issue of no fuel. As you may remember, last year I replaced all fuel lines and the fuel pump. The Carb was rebuilt about 6 months beforehand. The only thing I haven't replaced is the gas tank and the fuel sending unit. Today I pulled off the rubber connector between the rear fuel line and the one going into the fuel pump. I then set up a gas can about the same height as the engine and it turned over and fed from the can so I know the pump is good.
Now it might just be as simple as being out of gas but I didn't want to pour 5 gallons into the tank just to find out I had to take it out anyway. So the question is can the sending unit go bad in such a way to cut off fuel flow? If so, then for my own peace of mind, I'll pull the tank and replace the sending unit.
Yes, your sending unit can be clogged. You can try blowing compressed air through it.
There is a sock on the end of the sender fuel tube, this is what can clog.
The tube can also clog, just like the rest of the fuel line. The filter sock has probably fallen apart after 43 years.
As I remember it wasn't in the best of shape the last time I looked at it.
Who has a good replacement?
My filter sock was gone! Sending unit was coroaded up pretty good. Figure that sock went someplace? Yup you can really restrict flow with a clogged up sender. Easy enough to pull out and clean though. don't even need to pull the tank however I would at least flush the tank out too.
I saw that but I was going to replace the entire unit and I also saw that Don doesn't think very highly of the ones he has for sale.
Yeah, I read that too. Scott Drake, the manufacturer of these sending units, claims they test 100% of their units. http://www.drakeautomotivegroup.com/Store/Product/C8ZZ-9275-C.aspx?wid=141
I'm going to pick up one of these when I switch to 3/8" stainless fuel line.
http://www.virginiaclassicmustang.c...S-FLOAT-BEST-QUALITY-38-INCH-INLET-P2376.aspx
For now, I just cleaned out my sending unit with carb cleaner and compressed air and put it back in. Then I put some MMO in the tank to keep it clean.
How much MMO per tank?
if you put a piece of rubber line on the sender out let and blow into it with the cap off---if you hear bubbles the sender is clear---if there is a minute crack in the hose comming out of the tank , it wont suck---if every thing is new and clean , i'd recomend a fuel filter near the sender
doctordesoto
MMO is $17 per gallon and it takes about 6 oz per tank. $0.80 per tank. I use it mostly because of my compression ratio (12:1). I can't tell the difference between 91+MMO and av gas.
Discussion Starter #13
I had time today to pull the tank and what do you know, the sock had disintegrated. Glad I replaced the sending unit because the float was full of fuel. I ran the air hose through the line just to make sure there wasn't any further blockage and put 3 gallons into the tank. Poured a splash into the carb and she fired right up and sucked in the fuel from the tank. I am not sure if the gauge is working or not considering it isn't but an eighth of a tank. Carb is a mess with the idle circuit (Motorcraft 4300) but I am making progress.
1 - 13 of 13 Posts
