I need to know if the car will start if the nuetral safety switch is off the car. I have a new TCI sizzler and the thing came with a universal shifter linkage. Doesn't look like it will accept a NSS. Not enough room.
Also-
The 24 spline tranny secures to the flexplate with nuts to studs on the T.C.
I think a 26 spline secures with bolts. are the bolt holes in the same place and meet the holes in the flex plate?
The new tranny is a 70 and up 26 spline while the old one is a 66-69 24 spline.
AHHHHHHHHHHHHHHHHH
need to spend more money.....Wife pissed........help..........
You can start it if you jumper the switch out. But, you'd be better off and safer to figure a way to hook it up properly.
Discussion Starter · #4 ·
Just talked to TCI and I have to switch out the lever out of the old tranny...... Oh Well. Did get a new TCI 2200 stall coverter though!!!!
Discussion Starter · #5 ·
Just switched the manual shift lever and NO problem........
