If you are using air shocks to compensate for bad rear springs, do not use high pressure or you could damage the floor where the shock mounts or if you are lucky only break the shock bracket at the axle. Either way not good.Not often - but sometimes my C4 gets stuck in park and I have to go underneath and rap it out of park. Something bent perhaps or ????
Also how much pressure can a standard air shock take?
