Hello All, I have a simple question for anyone in the know. Are the nuts for the bolts that hold the seat tracks to the floor pan secured to the pan? I see no nuts underneath the pan or any access holes.
With any luck you'll see some rubber plugs in the floor from underneath. Pull the plugs and undo the nuts with an extension and a socket. At least that's the way it works on earlier models.
As far as I can remember,the nuts are fastened to the floor pan. Your bolts should come straight out. I have taken my seats in and out many times without a problem.
The nuts should be inside the car attached to studs screwed into the pan.Put the seat full forward and undo the back ones first,then move the seat all the way back and undo the front 2.If you do the front ones first the seats want to fall back and bend the rear brackets.
