1 - 2 of 2 Posts
Does anyone have any tips or ideas on how I could remove a broken bleeder valve from the caliper of my '70 XR7? I'm hoping that I can get it out and not have to replace the entire caliper...
Terry Fulwider
Nashville, TN
If you dont already have a good EZ out set you might as well just bite the bullet and go ahead and save yourself the trouble and get a rebuilt cailper. My experiance tells me you may end up putting heat on it to get it out which would require rebuilding the caliper anyway. Seems someone used to make a replacment that you had to drill and tap the caliper anyway, so in the long run just replace it.mm
1 - 2 of 2 Posts
