We have completely rebuilt the braking system on my 68
cougar. Includes the following:
New brake booster
Rebuilt master cylinder
new front discs
new front calipers
new front pads
new rear cylinders
new rear pads
turned rear drums
new rear brake lines
The brakes worked well until the first hard stop, now the brakes
are poor. The master cylinder is holding pressure, the booster
works, I was stumped. The brake warning light never did work as
the P.O. disconnected the switch on the proprtional valve, problably many years ago.
When I reconnected it of coarse the brake warning light comes on. I resorted talking the cougar to my mechanic who insists that the proportional valve is stuck in one extreme end (off centre)
inside the brake valve and is causing little fluid pressure to the system. He has not been able to move the valve to centre or as it appears at all, and still poor brakes! So........... 2 questions.
First, if the brake proportional valve is seized, can this somehow
block fluid pressure to the brakes, and would a working one fix the problem? Second, what have I overlooked? Sometimes your mind dwells on one thing and overlooks the obvious. :1zhelp:
New brake booster
new front discs
new front calipers
new front pads
new rear cylinders
new rear pads
turned rear drums
