when I put the parking brake on the warning light does not come on. Where would the switch be?
My best recollection is that there is a bi-metal switch on the parking brake shaft inside the car and under the dash. Since it is an XR7 the warning light should be in your overhead console. The switch may be out of adjustment or broken, a wire may be loose or broken, a fuse may be out and/or the bulb in the console may be out.
Thanks, all the other lights work in the console so I am thinking switch, maybe dirty or stuck or something, know i need to find it and check it out.
