1 - 2 of 2 Posts
My brake light switch has gone bad in my '68 and Im not sure where the old switch is and what the procedure is to replace it. It's a '68 with manual drums all the way around. Any tips are greatly appreciated!
Thanks!
It's on the brake pedal arm mounted around the pin that goes into the master cylinder. Make sure you get an exact replacement or it won't work correctly. Check with West Coast Cougars to find the right one.
1 - 2 of 2 Posts
