1967 XR7 289 Auto
I am driving a 67 Cougar Standard with drum brakes all around. I recently rebuilt the front brakes with wheel cylinders, linings, and hardware kits. After adjusting, and bleeding the fronts, everything worked fine. Now the Brake light comes on when I start the car but goes out after the car has run for five to ten minutes. The brakes work fine other wise. Could this be a sending unit going bad? Any thoughts guys?
Thanks.
BS
do the check
If your not leaking any fluid,all the vacumes are on and itstops like it should.check the E-brake cable for slack,I would replace the sending unit.I found mine at a daeler for10.00 bucks
