1 - 9 of 9 Posts
My brake lights are not working but my reverse lights and turn signals work. I was wondering if this was a fuse issue, or an electrical problem. Also..where is the fuse box located on a 68 Yr7 coug? thanks a lot
I dont know about the xr7, but on my 67 std. the box is above and to the pass side of your gas pedal. Its a black box with a bunch of glass fuses in it.
Could be a blown fuse. You can pull the fuse to see if the small wire inside is still intact, but the best way to tell is with a voltmeter. I have seen fuses that look good, but do not have continuity.
If it's just the brake lights...
there ae two most likely culprits; the fuse or the brake light switch. I'd check the fuse first, if it's good check the switch. they're relatively cheap and easy to get at a local parts store.
I had the same problem with my Cat, its probably the brake light switch. The switch is located at the top of the brake pedal arm. It's a cheap part maybe $5 dollars at Autozone.
thanks for the info guys. i found out that the fuse was blown, so i replaced it and it works perfectly. Just in case, what does the brake light switch look like?
ryan
It mounts on the pedal arm
up high, almost under the dash. There are two wires going to it.
That's what I get for reading these posts...
My brake lights went out this morning!!!
I know, I know - check the fuse and the switch!!! :D
1 - 9 of 9 Posts
