My 69 XR7 currently has the stock brakes + tire/rims and my next project is brake conversion + rim/tire upgrade. Looking for 4 wheel brake conversion kit recommendations + the needful rim/tire sizes.
Did some research on wheel size com which suggested
225/50R17,​
225/45ZR18,​
235/45ZR18 can be used (depending on brake caliber rim clearance​
needs) without wheel/axle modification. Anyone used any of these configurations without clearance issues?​
I believe the above sizes would require either the 17x8 or 18x8 sized rims depending on the brake conversion kit clearance needs.
Hoping to do the 4 wheel brake conversion done the right time.
My setup: 2005 4 wheel Cobra 2005 discs/calipers with street or track bracket kits. Front 245/45-17 on 4.5 bs 17x8 wheels, rear 285/40-17 on 17x9 5.25” bs wheels.
Thanks Isabel. Did you have to do the Shelby drop on the front end to handle the 245/45/17 sizes?
