I have a '68 that originally came equipped with power drum brakes. When I bought the car there was a set of disc brake rotors, spindles and calipers in the trunk. The calipers are the four piston style which I thought were used only on the '67 Cougar and that Ford switched to the single piston calipers in '68. My car's build date is Dec 7, 1967. Which calipers are correct for my car? I also noticed that WCCC lists different brake line kits for early and late production '67s. Assuming I go ahead and use these parts and they are from a '67 what is the difference between early and late 67 brakes? Which front brake line kit and hoses should I use, early or late '67? I know I will also need a different proportioning valve but I believe those were the same from '67 to '73 for disc brake cars.
BTW, I'm sure some of you might have seen this same question on other Cougar forums but so far no one has replied elsewhere. Call me impatient or just looking for multiple opinions.
