All,
It took me a little bit (and a broken radio), but I figured out why my 68 Cougar was idling rough when I pressed the brakes. I have a noticeable hiss coming from under the dash. I've since remove and plugged the line into the booster. No power brakes right now, but it runs much better when stopped. My guess is a bad seal/valve of some type around the inside plunger. Is that something that is repairable outside of completely replacing the booster. And, if I replace the booster, should I just replace the master cylinder too and get it over with? Best as I can tell, it's all original.
Thanks,
Greg
Thanks,
Greg
