1 - 12 of 12 Posts
Has anyone had any expierence removing undercoating. I'm sure there is some kind of solvent to soften it up so I can atl east scrape or blast it off with hi pressure water. Any help is appreciated.
If it is the asphault based crap, you can hand sand it or maybe Eastwood has some sort of nasty chem you can use to remove it. The original thick undercoating in the wheel wells is like this. I hit it with a die grinder and wire wheel, and it just smears around when it heats up.
Try NAPTHA or M.E. K. but be prepared for a nasty job.:(
Don
A wire wheel on a drill does work, but it needs to be in reverse, also a scraper and torch does the job to. I did my whole under carriage that way, I came out looking like mud man though, lol.
Rick
Thanks for all the tips. I'll try them all till I find what works best.
Rustproofing or rust causer?
You really, really, really don't want to get me started on this subject! That dang 'rustproofing' does exactly the opposite of what it is supposed to do. My Alpha Cat had the undercoating, and all it did was trap the water between it and the metal. Rusted out real fast! The same thing with the 'gravel-guard' stuff they put on the lower surfaces of my 85 Turbo Coupe. By the time you noticed that it was swollen with rust underneath, it was too late! Oh, and the underside of the Turbo Coupe was not rustproofed and it was rust free when I gave the car away...
Anyway, back to the rustproofing removal, I was able to scrape a lot of the rustproofing off with just the putty knife without resorting to heat. A lot of it was hard and brittle and removed in big chunks. I did the heat and scrape with what was left of Alpha Cat -- that is what was left of the car after I replaced the floors, front inner fenders, rear inner fenders, etc. I used a bernz-o-matic torch with the flame spreader attachment and a putty knife. I cleaned up the residue with kerosene followed by a lacquer thinner wipedown. Actually, I got disgusted in the middle of all this and that's how the car sits seventeen years later. :realmad:
Of course, you have to remove all of the interior of the car, including the carpet and sound deadener and also keep an eye on wiring harnesses! You also gotta be careful around the fuel ines and brake lines on the underside as well. You really don't want your Cat going up in flames!
this worked for me
I rented a big steam cleaner (hot) from home depot.I cleaned every thing.It cost me 50.00 for the day.Take note-do it where you have alot of room(blank)flies all over the place,It took 20 years of dirt and under coating off and It cleaned places that were hard to reach. Dan
Thanks Dan. I was actually considering that very idea. I used a cold 1300PSI and it took a lot off. I thought a Hotsy would be even better.
next week
Im going to get it again next week.Im doing all our vehicles.the garage floor ect.Im glad I held off we got pasted with the snow ,ice and salt hopfully for the last time.
Discussion Starter #12
I have a couple of grease spots that I bet it will rip through.
1 - 12 of 12 Posts
