First of all, thank you Royce for the recommendation of Dennis for adjustable rockers...I have them already and they will be going in soon. That is where the question comes in. I don't have a manual for where to turn the engine to set specific valves for the rockers. I know TDC will get you the #1 valves, but then is it 180 degrees, 90, 317? I've done this with the small block fords some time ago..but don't remember the sequence. If anyone can respond with the proper way to set these adjustable rockers, that would be fantastic...also, he (dennis) recommended Moly Lube for the ball/cup connection of the push rods to rockers...what kind of lube is this? Strictly engine lube? grease? what would work? Thanks!
Chris Clackless in Bakersfield
