1 - 2 of 2 Posts
The "Belts" warning light on an XR7 I have comes on and then goes off after about 30 seconds. However, it later flickers on and off, sometimes staying lit for a few minutes at a time. I've checked ground at the dash light and it is OK, but does anyone know where the relay is for this circuit? I don't want to disable it if I can help it. Everything else on the car works.
Randy,
This relay is (usually) on the left bottom of the cowl behind the instrument cluster and shares space with the LF relay and circuit breaker. If it is not there, it is to the left of the radio/AC/heater controls on a bracket that is attached to the lower dash.
Hope this helps.
1 - 2 of 2 Posts
