1 - 13 of 13 Posts
They fit
I am running a 1.25" spacer front and rear
Before...
After...
Its amazing how much a set of wheels changes to look of a car :)
I have a similar, 16 inch wheel and tire on my 68, and they seem to do fine with a 1.00 inch spacer. Because of the way they fit my 68, I got the exact same set up for my 69! Now I am wondering what that difference of a quarter inch will make......Hmmmmmm
However, your set up looks good indeed! The 16+ wheels are definitely growing on me!
I like! Fills the wheel well up real nice adn doesn't look out of place. I see the "Men in Black" dog admiring them too! ;>)
Yeah, she is my "helper"... if you can consider it help with her being under your feet with EVERYTHING you try to do :)
YEP - I know exactly what you mean - I lost my helper 3 years ago... ;>( still miss her.
got the Cougar aligned today...
It was WAYYYYY out of alignment.
Also found out that the new wheels are rubbing on the upper control arms when turning very tight. I will pull the tires off and do a little clearancing on the control arm and all should be good. Im glad I went w/ the 1.25" spacer rather than the 1" spacer... they wouldn't have worked.
It drives COMPLETELY different than it ever has... good front end bushings, bigger tires and wheels, and a fresh alignment...
Mmmm same style I'm looking at. What backset did you get? The info I found was this is that with 17x8 with 4-1/2-inch back-spacing. I plan on going with a 245/40 tire front and rear.
Discussion Starter #12
Mine are the newer style, so they are around 6.5" back spacing, and I have a 1.25" spacer all the way around. Could use 1.5"
1 - 13 of 13 Posts
