1 - 13 of 13 Posts
Hey experts, is it really necessary to use two different guns for bc and cc? Don`t want to spend a fortune on another gun that I might use 5 times in ten years. If a gun is cleaned very well in between base and clear, will that be good enough?
I only have one gun and use it for everything. Like you i didnt want to spend money on other guns, those sata's ain't cheap.
clean it out really well and you can use it. What kind of gun? some work better for clearcoat than basecoat, but theres nothing wrong with using the same gun for both.
GEO! good gun. youll be fine.
Don't know about the expert part however I use one gun and have different air caps, needles and fluid nozzles for the base and clear as well as acrylic enamel.
John
1.3 should be fine for both. If you told us you had a 1.5 or 1.7, id be worried, but 1.3 is ok.
Thanks guys. I am painting the jambs and undersides very soon. I will post some pics when I do.
1 - 13 of 13 Posts
