i ran mine similar to how black 67 did his. however, mine is different. mine is still running thru the kickpanel and thru the wiring channel by the 1/4 window and over the 1/4 arch. i am relocating my starter solinoid to under the rh hood hinge. 3 reasons. 1 closer to the starter, 2 easier to connect the rear cable to. 3 easier to run wiring, power distribution. in the front i have my cable coming out the firewall just under the heatercore/evap core lines. in the rear, i have 3 holes in the rh drop off. the main power to switch , switch to battery and neg battery to frame. do not forget to run a heavy gauge frame to engine cable up front too!
