So, I got the carpet tore out of my 69,and found a lot more than I had bargained for. There is significant rust damage on the floor. I knew this going into it, but I had hoped that the rails were good and all it needed was a floor pan, some patch panels and a little bit of filler.
Here is the bad, The drivers front rail is showing a lot of rust, not sure how bad it is just yet, but it isnt a good sign. Also, the passenger side floor pan is missing all the way up to the toe board, and the drivers side is about the same. The trunk floor on the passenger side has rusted through, where the grommet/plug sits between the fuel tank (which looks great) and I would assume, over the rear rail. My quarters are rusted through in a few spots around the wheel arches. The rear floor pans are okay in places, but are also prime candidates for replacement. The thing that worries me is that the fronts of the boxes or whatever they are called that support the seats are also pretty much rusted through.
Is this even worth repairing?? I love this year, and haven't really been able to find a decent roller or even a donor that I can find within a couple hundred miles that isn't $3k+
Should I try to find a clean(er) donor or roller and start over? Or should I get a new MIG welder and some sheet and angle iron and make it work?
