1 - 18 of 18 Posts
Wow! In 3 days, I've had 3 things break!
First the window came unglued, then my speedometer died, and today, I blew a tranny line on my way home, and well, I have a trail for over a mile turning right into my driveway.
When it rains it poors huh? Anyone else have things break right after each other?
Hey Chris. They say bad things come in threes. Hopefully your safe now. ( knock wood, cross your fingers, ect....)
Bruce
Yeah, like 3 speedodometer cables breaking on me all within a period of 4 months. They were all lubed properly, just 1 of them there days when you think its all set n WHAN something else goes bad.
thanks
pat
WHAM,
man i must be getting tired i cant see straight lol..
pat
dont get me started!!!!!!! ok, since you ask :) The chrysler blew the chain last week remember. I replaced it, got it running, it overheated all the time and collapsed the upper rad hose. Got a replacement rad hose, still overheated, but not bad. Then the fuel pump excentric BROKE off 3 days ago, so I had to tear it all apart again this weekend and fix it. It sheared the pin of the end of the cam, so had to get a new one. Got it buttoned up today, and it still overheats....
Now the Fairlane, the tranny tube was cracked and leaked alot, so I found a replacement one, it was a tight fit, but it fit. Adjusted the linkage again, and fired it up, and it still leaks. Now I have to tear it all apart again and figure out why its leaking. I really miss working on my Cougar, so when these 2 cars are finished, Im pulling out the Cougar and going to go nuts on it and going get it finished this spring/summer. A bad day working on cars just isnt the same if its not the Cougar ;)
Rick
sorry Chris, hope your luck changes for the best ;) You've had 3 strikes, now its time for good luck.
Rick
Well, I'll find out tomorrow, I need to bring it down to our shop to fix it, hope I make it with the tranny fluid in tact. Just re-filled it up today... and it leaks pretty fast when running. Luckily its not that far.
I blew a line on a 68 I had a while ago, pumped it dry. Didn't seem to any long term damage. I just changed the fluid after I fixed the line. You should be fine..
Bruce
Murphys Law
Hey Mark, now we know where murphys been hideing!
shane:1poke:
Discussion Starter #14
Thanks guys. I brought it to the shop, and everything is all fixed now. And very professional. Thanks!
Discussion Starter #15
Just when I thought it couldn't get worse... the tranny took a dump on me, on the way to Steve's (sixt9coug) house today... so now I have to find another one... and to top it off, Steve let me drive his 69, so now I'm drooling over a 351 again... :)
Chris
for the meantime take steves fmx that he has sitting and use it better than nothing
thanks
pat
Discussion Starter #17
Yeah I was looking at it today, has a 69 date on it... but is it worth the hassle to put it in, if it's bad? I'm thinking about just finding a C4 in the recycler for cheap.
true.. chances are im not gonna use that FMX............ someone should put it to use before the recycle guy picks it up for a core charge.
1 - 18 of 18 Posts
