okay here is where having a Ask royce column should be installed, anyways...... Royce what is the measurments i should be looking in between the shock towers on a 68 cross bolt hole to bolt hole. I am Repairing a nasty job done on Johns 68 GTE and i am trying to get it as close as possible. off hand cant remember what I was able to beat and torch the measurement to but i have both within an eighth of an inch from being the same. but having said this both shock towers have been mega welded and i want to get it correct as possible. Either case if i cant fix it i will need the measurements to put the new towers in anyhow. thanks.
