Yes, here's a link to exterior light components: www.cougarpartscatalog.com/19671968.html . The taillight kit is the 3rd and 4th one and the halogen headlights are further down about the 35th and 36th item on the link. JohnCan the head light lamps be upgraded to halogen lamps on a 68?
How about the tail lights, brake lights and turn signals, can these bulbs be upgraded to be brighter?
As Bob stated with the relay setup. You will definately need it with the halogen bulbs.Hella makes bulb housings that take cartridge H4 and H1 bulbs, there may be another manufacturer as well, but I would recommend staying away from the chinese junk (which there is a lot of out there). The Hella stuff is not cheap but works well, almost drop-in. You'll need a headlight relay system as well to go with the bulbs, they draw too much current to be used with the stock headlight switch. For that I recommend the kits that Bob at RCCI (http://www.rccinnovations.com) sells.
Did you have to do any special wiring for the halogen lamps you got from Ebay?there sure are....
i got mine on Ebay for 150.00 for 4 lights! View attachment 25405
