I have a '68 Standard 302 2v that I use as a daily driver. I've had the engine redone with a 4 barrell and a bigger cam in the last year and a half. My C4 is about ready for a rebuild and the rear end is starting to grind a little. So I've decided to upgrade. I've priced an AOD that I'm going to have a trusted mechanic put it in and I just want to make sure that the conversion isn't too big of a change. Other than the possible drive shaft length, Will the AOD bolt on to my 302? Any help is appreciated because I'm carpooling with my wife until it's done...
Thanks so much. I love this house you've built Logan.
Brian
Brian
