was wondering if anyone knows if I can buy these 2 little pieces anywhere(68' door hinge)? mine are kinda ragged out and sloppy. they seem like they would be easy to replace. just grind off the backside of the stud and they should come out easy.
Thanks,
Josh
The parts you are citing do not usually go bad and to my knowledge are not sold. What does go bad is the bushings and the pins if the bushings are worn enough. I'd bet that if you do the bushing and pins, the hinge will work "just ducky" and the parts you are citing as sloppy will work well too.
Weren't the hinges I just dropped off better for a rebuild?
Im rebuilding the hinges myself and putting grease zerks in the pins I just thought I would ask while I have them apart and at the sandblaster. Im not too worried about these so much im just kinda anal like that....:)
