Status
Not open for further replies.
1 - 1 of 1 Posts
This is a very basic overview of how to use POR-15. I'll be adding and revising this section as necessary. For now I just wanted to give those who may not be familiar with POR-15 what its like to use.
I've closed this thread to responses to keep it neat. Please open a new topic if you have any questions.
Thanks!
POR-15® is a moisture cured coating that chemically bonds to rusted steel to form a rock-hard, nonporous coating that won't crack, chip, or peel. It works by isolating metal from moisture; without moisture present, steel can't rust.
For surface preparation rusted surfaces are best; seasoned metal and sandblasted surfaces are also good. Surface rust will actually allow the Metal Ready (step 2 below) to act more aggressively.
For best results, follow the POR-15 three step process:
<b>1 - Degrease and Clean Surface</b>
After wire brushing loose rust, or sandblasting, clean surface with Marine Clean - an alkaline cleaner that will strip away any oil and wax.
<b>2 - Neutralize Rust - Etch metal </b>
Prepare the rusty metal surface with METAL-READY™. As a rust remover, METAL-READY™ will neutralize rust, etch metal for better adhesion, and coat the metal with zinc phosphate to encourage deep chemical bonding of POR-15™ to the base metal and rust.
<b>3 - Apply POR-15 Rust Preventative Coating</b>
As the moisture resistant POR-15™ bonds to the rusty metal, it will form an unbelievably tough, almost ceramic-like finish that will not crack, chip or peel.
<b>A Word About Ultra-Violet Sensitivity</b>
POR-15® is sensitive to UV light (sun) and must be topcoated for prolonged exposure to sunlight. Failure to do this may result in long-term damage to the POR-15® coating. Topcoating is not required for areas not exposed to sunlight.
If you do need to topcoat you can use our Tie-Coat Primer (http://porshop.com/porshoptiecp.html) which is designed to help any other paint adhere to POR-15. It goes on thick and sands real well to a smooth finish.
Otherwise, you can also apply a topcoat of paint to the POR-15 while it is in the "just beyond tacky" stage where it won't leave a finger print, but is still not fully cured (usually about 1 - 3 hours after application).
<b>General Handling Tips</b>
<LI> Don't get this stuff on your skin. It won't come off for several weeks.
<LI>Make sure the surface your coating is bone-dry.
<LI> Pour from the container what you'll need for a session and immediately close it to prevent exposure to moisture that will begin the curing process.
<LI>Read the directions and follow them closely for the best results. This stuff ain't paint!
1 - 1 of 1 Posts
Status
