Hi all.
Question whats the best radiator and electric fans setup to use? I am gonna switch to a alumn radiator cause it desipates the hea faster and wanna switch over to a electric fans setup.Should i go w/ a 2 small fans setup or a 1 big giant fan? i know its gonna be a puller .Plus a alum. water pump. are they efficiant? The reason i ask this is because after the daytona show 2 weekends ago whem at a sitting idle i wanna keep the temperature cool .I do have a fan shroud and a 195 thermostat and a 3 core 20 inch radiator. Im not after the factory look , and will soon be tearing the car apart and possibly the top end of the engine off n replacing the heads w/ a set of 4v closed chambered heads.and a cam
thanks
pat
thanks
pat
