:1zhelp:
This has probably been discussed in the past, but I can't find (I haven't looked that hard) the archive...
Since '93, I've replaced/rebuilt my alternator three times and my voltage regulator twice, and I'm getting tired of it. I can't expend the time or money redoing the wiring (probably the source of most of the loss) so right now I'm just trying to get a good, modern, high-output, internally regulated, off-the-shelf alternator installed. I want to use something I could get at any Pep Boys/Autozone/etc, so I've been looking through Ford stock equipment parts lists... I found one for '93-'96 (I think) Lincoln/Mercury v6 applications, internally regulated, something like 200Amp output, with roughly the same external dimensions (close enough that the adjustment bracket can adapt the size). The only physical change required would be to swap the pulley (or convert my cat to 6-rib serpentine...
). Has anyone tried anything like this before? Does anyone else have this problem? Any other solutions that come to mind?
Thanks for all of your help!
