Yes, and it does has 13 blades.Sami, are you referring to the alternator fan blade, if so, does it have 13 blades? John
Thanks for the info. Here's a link to Deadnutson with a pic of the alt fan blade: www.deadnutson.com/catalog/item/7070330/7164128.htm . It says the finish is zinc dichromate, I'm not sure if that is the same as yellow zinc as DSO84 listed. Just putting the info out there. Edit: I just searched zinc dichromate and it is the same as yellow zinc. JohnYes, and it does has 13 blades.
