1 - 9 of 9 Posts
Hey guys need your help. I have the full Laurel Mountain Mustang hi performance Cougar suspension kit. After installing the new idler arm and pitman arm my car doesn't turn all the way to the right like it used to. I'm assuming it's the idler arm...What did I do wrong and how do I correct it?
Start driving oval tracks?
I had my mechanic do the install. Hmmm....You think when he disconnected the pitman arm he turned the steering wheel to the right a turn, causing me to lose some of my turning radius? I thought you could replace the pitman arm without having to touch the steering gearbox other than to pull the pitman arm down?
With your wheels straight, turn all the way left and count turns, then turn right and count turns. Should be the same, if not then the pitman arm might be off , although I though the pitman arm had a wide spline on it for alignment.
I don't even need to do that and can tell you that I have at least 1 more full turn to the left than I do to the right.
That was my first thought. The steering box wasn't centered before the pitman arm went on.
There is a notch that should help line up the pitman arm correctly if not make it difficult/imposible to install wrong. Is there an chance it is the wrong idler? I think there is a difference between the manual and power steering idler arms. See pitman arm notch here:
http://www.cougarpartscatalog.com/1000325.html
1 - 9 of 9 Posts
