1 - 1 of 1 Posts
I have a '67 XR7 instrument cluster with a inoperative tachometer (the previous owner had jumpered the coil wire to bypass the tach). Does anyone know if there are any aftermarket tachometers that have the same or similar sweep over the RPM scale as the factory original? I'm thinking of removing the inoperative tach and using its needle and housing around a modern replacement with a more standard 3 wire hookup. I could get a new gauge set, but I really like the original style.
Thanks for any input!
1 - 1 of 1 Posts
