i'm in the process of adding power windows to my 69 XR-7
Does anyone have pictures of where the power window relay is supposed to mount near the solenoid and the routing of the main power wire to the firewall? Where does the wire go through the firewall?
Thanks,
you would think someone would know this, none of my cars have factory power windows
I have um on my '70 Ecat, I dont know where it is located but assume it would be under dash near fuse box? anyone else?
I am in process of making corrections on it to sell soon, I will try to locate it or better yer I think I have a schematic or wiring diagram, I will lokk & PM you if I discover it.
Sorry I have no pic. But it gose on right shock tower may be 2 marks in the metal, wire goes though fire wall under left shock tower bracket mounting at fire wall, should be a indent to drill fire wall, I think a 1 1/4" hole saw. Not shure on size of hole but check frist
Thanks for the info - if anyone has a picture of the exact mounting and firewall locations it would be a big help.
