The mounting screws on the accelerator pedal are loose and spin in place. Is that a sheet metal screw? Is there a nut on the back or do they screw into sheet metal? What's the fix if it's stripped?
Thanks!
Thanks!
Sheet metal. Sounds stripped. Simple fix is to beat the hole closed from the back but getting under there might be a bit tight.
