1 - 15 of 15 Posts
Ok, I haven't post in a long time. Just recently started back working on my Cougar. So today I had some spare time and decided to get creative. I had a bunch of spare parts laying around and decided to se if I could do something to eleminate the front bumper. DSCF0884.jpg DSCF0881.jpg DSCF0882.jpg
I will be adding something behind to protect from front impact. Plan is to finish getting everything in shape and the make a 1 piece fiberglass front nose section.
Yes you do, I have been toying with this car for 4 years. I plan to turn this into an Elenor Cougar. misc 137.jpg wheel flares 006.jpg
I see what you did there with the piece of a hood and add'l fender extensions, what did you make the "bumper" out of? Looks like a foam something or other that you have sculpted to fit the space where a "bumper" would go in your vision. I'm liking what you are envisioning!
The material I am using to form everything is indeed foam. I puchased it a florest shop. Very cheap and easy to sand (but does it ever make a mess). I am also using a band saw to cut everything close to size the hand sanding to fit.
I have always wondered what that would look like done that way. Look forward to see what it will be like when finished. Nice work!
Wow, nice work man. Did you do the fiberglass work for you deck lid and rear extensions, or did you order the kit that I have seen floating around? I attempted to do the same for my 68, but I couldn't the finished look I was going for on the rear so I scrapped the project for now.
now fill the center rect hole where the mercury man is and make a license plate filler(get rid of the flat for the plate )and she'll be real smooth
doctordesoto
Discussion Starter #12
Doctordesto, I am in the process of doing just that. Although I plan to add a front spoiler and may be inclined to make the front valence the same as an R- Model Mustang. Also plan on adding a GTE hood scoop.
Discussion Starter #15
FFR428, thanks for the feedback. Do you happen to own a Factory Five Cobra? I use to visit that site when I was building my Cobra kit and seem to remember some one using FFR428 as the user name.
1 - 15 of 15 Posts
