9" spline count
Logan is correct, for the most part.
Most small blocks - 28 and
most big blocks - 31. I have seen some 390 cars with 28s (69 Mustang), as well as a 351CJ 4-speed car with 31s (73 Mach 1).
The
only sure way to know for sure is to pull an axle, sorry.
My buddy's Boss 429 had 28s in in when he got a hold of it. Reason? The previous owner had drag raced the car extensively and found (the hard way) that 31-spline axles would snap without warning, whereas the 28s would twist first. The guy would paint a line the length of the axle shaft, and when they twisted more than a half-turn, he'd get new axles. Good enough for me.
I did the same thing when I put a 9" under my (shhhh) '74 Camaro drag car. A rear end from a 71-73 Mustang/Cougar fits a 70-81 Camaro perfectly! If you use an Econoline diff yoke, you can even use the stock Chevy driveshaft and u-joint! I used a Motorsport driveshaft and bigger Ford u-joints on mine since I was also replacing my 4-speed and going TH400 at the same time. My Chevy big block 396 put that Camaro down to
[email protected] using 28 spline axles. Nothing wrong with them at all.
