Yesterday I went to swap out the center and ran in to a problem..I couldnt get the driverside axle to go in all the way. So I pulled the center back out to find on the driverside there are 2 parts to spline that the axel slides into and one has moved the alignment is off. Any easy fix for this? I have used this center before with no trouble and even had the axle all the way in yesterday on a dry test fit. So I guess I moved it some how but can seem to get it to align back up.
