My car currently has an 8 inch in it, with 2.79 gears... This summer I came across a 9 inch, which I took apart to find a 4 pinion 28 spline tack lok in it, and a set of 3.23 gears. Google tells me the tack lok will fit in to my 8 inch, but I was wondering if anyone could tell me if a 9 inch set of gears will fit a 8 inch? The axles are interchangeable I have been told, so the theory would be to do a straight gear swap and toss the track lok in and save myself cutting the 9 inch to fit.
What did the 9 inch come out of? I say just put the 9 inch in the car and go from there instead of messing around swapping parts to make it fit the 8 inch.
thanks
pat
8-inch and 9-inch traction loc units are NOT interchangeable! The carrier unit is made for either the 8" or 9" ring gear.
The 9 inch came out of a 70's lincoln continental, which had a 460 in it, probably the reason it had the tack lok. But yeah, google tells me that some of these lincolns had a 9 3/8 diff, which is similar, but still slightly different... So I can't even really say if its a 9 inch or not, because the pictures I see of the two make them out to look identical in my eyes. Either way though, I think the gears fit both 9's, so I guess I could always cut it down anyways and stick it in, seeing as I have all the parts from it still anyways.
Was the Lincoln rearend set up for coil springs? If so, lots of differences beyond just the width of the rear. I'm also a little surprised you'd find a traction lok in a Lincoln. Depending on your budget, you may want to consider an aftermarket center section for the 8". Or dig up a 9" housing for a mustang/cougar. I think anything 67-70 will work but double check the width. I do believe the axles will interchange.
8" and 9" are a lot different. I bought a used 9" out of a bronco and had it narrowed. I probably could have done it myself but i went ahead and took it to a shop that had a jig to do it. They only charged me $100 and it turned out perfect. I want to say I had it narrowed to 53" overall length but I can't remember. When I had it narrowed and the center section rebuilt I took it down and had custom 31 spline axles made to fit. Overall, it saved me about $1000 between buying a currie rear-end. If you look on craigslist you can probably find a 9" for $100. Thats how much I paid for mine. I have a small album in my profile that shows some pics that way you can identify 9" between 8".
