Opened the trunk of my blue 73 some time back to discover the trunk had leaked and all of the memorabalia from previous Fabulous Fords shows was soaked and/or moldy. Peeled back the gasket and found some rusted through holes. Removed the old gasket, ordered a new one, and tried to clean up the area. With my incredible knowledge of body work (none) I used what I had, a drill driven wire wheel to clean down to metal and found some Rust-Oleum that was a pretty close light blue color.
But the holes are still there. I have taken some low res pix hoping I can attach them here to show the size.
My question: What do I have to do? Do I have to go to a body shop and have them welded? Would some Permatex work? JB Weld? Bondo? This car is probably driven a hundred miles a year and spends most of its time under a tarp. Still starts and runs. Looks good in the local parades. This is probably the one of my 2 73s that I will keep.
Any comments/suggestions (besides "what a frickin' amateur")?
Thanks.
Auto part Automotive tire Automotive exterior Tire Automotive wheel system Automotive exterior Vehicle door Bumper
Of course the right way is to cut out the bad section(s) and replace with clean sheetmetal. But if you treat it with POR-15 or similar product, and patch with JB Weld, the repair should last you many years.
I ended up getting a non-rusted part from a donor car for mine...
If that is the only hole you have, you (or a body shop) should be able to weld in a small patch.
Lead it! Propane torch, wooden spatula and a stick of 50/50. There's always brazing,..a simple process to learn. A local welding shop would charge around $40 for a few spots, do the metal prep before taking it down to them.
ALL METAL clean the area well , this can be worked like plastic but is made of metal with a epoxy hardener . Just make sure you clean it as well as you can , I mean removing the rust , apply the material follow direction on can . Smooth it over prime and paint . It is moisture resistant and will live a good life .
in the application less is best do light layers sanding in between coats .
http://www.amazon.com/USC-Metal-Filler-Putty-Quart/dp/B003BWERU8
