I have had this 73 cougar for almost 20 years and have driven it every summer over that time.... My issue for today is that a previous owner long ago put in a guage cluster in from an XR7
throughout the time I have owned this car the TACH, OIL, AMP and Low fuel have not worked. I always assumed that these were issues brought on as a result of the cluster change. possibly these were not part of the original cluster, and I just figured I would fix it someday... well someday is today.
The reason that I now am starting to make an attempt to correct these issues is is that this week, the alternator died and I had no way of knowing till it drained the battery down while I was driving and left me stranded -- also I have the time and money now which i have not had before as I am no longer a teenager ( as I was when I bought it ) and that my kids are also now almost out of the house. Damn time flies.
AMP Guage, I found two 10GA wires threaded into the engine compartment - tested them wiht a triple AAA battery and the amp guage deflects - WOO HOO, I know that one goes to the Batt side of the starter relay, but I now need to figure out how far up the alternator lead I need to splice in the other wire - so that the voltage differential across this wire distance properly that emulates AMPS, is correct - any advice?
OIL pressure - no clue - Is there a different sending unit I need to purchase? and will the wire in the harness that already exists work? how will I know if the PO hooked the existing wire to the new XR7 guage? are the harnesses different? should i just get a new sender and see if it works?
Tachometer - no clue. Did the standard cougar have a tach? - which wire was it, and how was this originally hooked up to the distributor?
LOW FUEL - I see this as a dead end, as I just replaced the tank and fuel sender, and the car does not have "something??" that I need down there at the sender, I see an additional wire in the harness that would connect to a pin on the sender and thusly to something inside the tank, but I think I recall reading that the "something" I need is unobtainum.
As I am new to this forum... is there anywhere where some schematics might be posted?
