Ladies,
Window cranks...
You can view what the cranks look like on any Mustang or Cougar vendor's website. The 70 has a color-keyed knob, whereas the 72 should be clear. The 70 knob obviously is replacable and bolts on. The 72 is riveted on and cannot be replaced. They are the same as any Ford window crank from the 70's and are quite common. Even most parts stores have generic replacements marketed by the red carded display 'HELP' brand. I've seen those parts in stores all over the country, so finding a suitable one shouldn't be that hard.
Door pulls...
I have a couple NOS ones laying around, all in black. My last good ginger ones are on AlphaCat. What usually happens is the screw that goes into the handle from the backside (through the door panel) gets pulled out of the handle when the little metal reinforcing clip that is molded into the handle cracks and breaks. The handle itself still looks good, but now there is no way to hold it to the door trim panel.
On BetaCat, someone before me made a nice chrome reinforcement out of 3/16" rod, bent it to the shape of the door handle, and made eyelets at each end. Then a nice decorative chrome screw goes through the eyelet, through the handle and through the door panel, being nutted with a large fender washer on the backside of the door panel. It actually looks quite good.
On the new PartsCat, some previous owner made pulls from a section of an old tooled leather belt (for trousers) and screwed that to the door panels, again nutted on the backside of the panel. I'm sure there are many ways to effect a fix, just use your imagination!!!
