Does anyone know if you can use the LED type bulb to replace the 1157 bulbs on the tail LAMPS for brake and turn signals? Mine are very dim and I'm concerned about safety. Any help greatly appreciated! Thx Chris
No....Check out the video link below. WCCC also has a chart of what bulbs and parts you need for the conversion
Yes you can. Caution. Your electrical wires need to be in great condition. You may also need to connect a relay on the circuits. They do make a big difference. Convert to the LED headlights too. Contact your favorite Cougar parts dealer for the best how to advice. Pearly models there is a resistor above the fuse block that regulates how bright the lights will be. See if you need that too.
