1 - 8 of 8 Posts
Hello, I have a 70 XR7 and am working on replacing the nose grille that had been taken off and would like to find out if anyone knows what parts or pieces are needed to fasten the grille onto the hood. Thank you, Rick
There should be a stud on each of the four corners of the center grill. Just align the studs with the holes in the hood and use a nut on each one to tighten it.
It takes two different nuts, the bottom nuts are 8 /32 and the top are self threading nuts.
Thank you Towcat. I did not the sizes and that the top was self threading. Thanks again,
Rick
Do you know if there is any rubber pieces around the edge of the nose grille that acts as a cushion against the body? or does is it rest in place as is?. Thanks,
1 - 8 of 8 Posts
