Thanks for the reply, very helpful...It's most often the vacuum motor seal, sometimes the internal vacuum motor diaphragm. I start with a tubing clamp (vice-grip will work if you don't have a tubing clamp) and clamp off the side that would provide vacuum to the closed position somewhere near the vacuum motor. if the doors go up that vacuum was lost through the vacuum motor. Its hopefully the seal under the rubber accordion boot. there's a kit to replace that. If it's the diaphragm, it's pricey to get a rebuilt replacement from that guy in Canada. Critter Creek Cougar Restorations – Headlight Vacuum Actuators If that passes the test start moving back towards the light switch, first do the same test on the other side of the vacuum bypass valve (somewhere near the windshield washer reservoir), then at the firewall going to the light switch. Also check every vacuum tube on the "closed" supply for cracks or loose connections.
Thanks for the suggestions. I appreciate it.It's most often the vacuum motor seal, sometimes the internal vacuum motor diaphragm. I start with a tubing clamp (vice-grip will work if you don't have a tubing clamp) and clamp off the side that would provide vacuum to the closed position somewhere near the vacuum motor. if the doors go up that vacuum was lost through the vacuum motor. Its hopefully the seal under the rubber accordion boot. there's a kit to replace that. If it's the diaphragm, it's pricey to get a rebuilt replacement from that guy in Canada. Critter Creek Cougar Restorations – Headlight Vacuum Actuators If that passes the test start moving back towards the light switch, first do the same test on the other side of the vacuum bypass valve (somewhere near the windshield washer reservoir), then at the firewall going to the light switch. Also check every vacuum tube on the "closed" supply for cracks or loose connections.
