The car is in storage right now, as I work on the Convert & Boss (2 car garage) I can tell you a bit of info. The "Cat" was around $20. They are avail facing R & L. I removed the ribbed backing and the crest by working on the pins peaned over in back. Once apart, I sent all the bright work off to a plastic coating shop. The base is now all black, and all I did was install a new Cat, and assemble.
