That's interesting that the original dealer put a spoiler on a non Eliminator car.As we are aware, a 70 with a 428 was a Q code and could have the Ram Air added as a factory option. Unfortunately, that is not the case here and I agree that as a "decoration" it somehow detracts. I have a 69 Q code but the dealer added the scoop and spoiler, so I left it that way. Might the dealer have done this...?
It has been discussed on the forum numerous times before. In 1969 & 1970 ALL Eliminators received a factory hood scoop, the only NON Eliminators that received a factory hood scoop were those equipped with a 428 and Ram Air. In 1969 they received a Vin engine designation of "R", therefore any other Vin engine designation, H, M, Q or S that was available and is not an Eliminator would not have a factory installed hood scoop. In 1970 all 428 Cougars received a Vin engine designation of "Q", and the only way to confirm Ram-Air and therefore a hood scoop (on a non Eliminator) is with a Marti report or Eminiger Invoice.That's interesting that the original dealer put a spoiler on a non Eliminator car.
I still don't know if non ram air 428's ever came without scoops.
For any Cougar, I prefer non ram air. But if it has to have a scoop, it might as well be RA. I'm not sure how much HP RA added, especially at under 90 MPH. What if it's raining hard and you're at highway speed, did water ever enter the scoop?
My car was used as a pure stock drag car from 69-72. The original owner (with whom I have had many conversations) says that he believed that at higher speeds the spoiler and the ram air added a little bit. He had the dealer add it because the dealer agreed to do it cheaper than the factory. I even have a letter from the dealer and a picture of the car the day it brought home.That's interesting that the original dealer put a spoiler on a non Eliminator car.
Thanks for the answer about non RA 428's. Yes of course I knew all Eliminators had the scoop, but didn't know about non Eliminators. That's what the question was. Also, I have never looked closely at a RA air cleaner, so was unaware of the drain hose. Thank you for that info too.It has been discussed on the forum numerous times before. In 1969 & 1970 ALL Eliminators received a factory hood scoop, the only NON Eliminators that received a factory hood scoop were those equipped with a 428 and Ram Air. In 1969 they received a Vin engine designation of "R", therefore any other Vin engine designation, H, M, Q or S that was available and is not an Eliminator would not have a factory installed hood scoop. In 1970 all 428 Cougars received a Vin engine designation of "Q", and the only way to confirm Ram-Air and therefore a hood scoop (on a non Eliminator) is with a Marti report or Eminiger Invoice.
As to water entering the scoop the answer is of course, that is why the rubber seal has a drain hose on it.
Scott,Rubber seal had a drain hose? You must be referring to the R code Mustang shaker hood scoop set up. The 1970 Q code "Ram air" system for Cougars was very similar to the 1968 1/2 Mustang set up. The rubber seal went directly to the bottom of the hood. The air cleaner itself had small drain holes in the bottom of it, to allow excess water to drain out, directly onto the intake manifold....you could argue that's not a good thing.....
Don't sound good to me. Sounds pretty stupid. But what do I know? I'm just a meat cutter & amateur tennis player. Never owned a RA car.Rubber seal had a drain hose? You must be referring to the R code Mustang shaker hood scoop set up. The 1970 Q code "Ram air" system for Cougars was very similar to the 1968 1/2 Mustang set up. The rubber seal went directly to the bottom of the hood. The air cleaner itself had small drain holes in the bottom of it, to allow excess water to drain out, directly onto the intake manifold....you could argue that's not a good thing.....
