my dash lights wont come on, with the parking lights\headlights. if i turn on the high beams then the dash lights work, I'm thinking the high beam switch. any feed back would be great
thanks
Could be your dimmer switch since the dash lights do work on at least one setting.....there is only one ground point via the inst cluster that I see, but the power feeds alternate via the headlight switch and that could be your problem as well.....
I just bought a new headlight switch , my question is how do you remove the knob\rod from the old switch so I can remove the orignial switch from the dash ?
thanks
George
You need to press on the little metal button on the right side of the switch while pulling out the knob/rod.
