69 XR7 Clevor
My 69 XR7 is for sale to fund a new project. $13000 or reasonable offer.
This 69 XR7 started out life as a Slime green XR7, 2bbl 351 Windsor car. It's been completely gone through and has had almost every mechanical part replaced in the last 2 years. Since it was put back together, it's had all of 2500 miles put on the car. When we started the body had 144000 miles on it.
Powered by a custom built 351cu in "Clevor", backed up with a rebuilt FMX Tranny with a TCI Convertor. Out back sits a freshly built 31spline 9inch rear with 3.50 traction lock. Every single part on the rear axle was replaced with NOS Ford pieces a few months ago, including all the brake work.
The suspension has been completed rebuilt. Up front it has 600lb springs and every ball joint, tie rod end, bushing has been replaced. The entire Power steering system is brand new too. All the fuel lines have been replaced with stainless steel from front to back. There's a new gas tank and sender as well. The rear springs are heavy duty units and KYB shocks are all the way around. The car rides around on 215/60/15's up front and 295/50/15's out back on Cragar Street Star wheels. The rubber is BF Goodrich radial T/A's with 95% tread remaining.
Every piece of weather stripping and rubber on the car has been replaced, all the windows have been rehung, though the drivers door window is misaligned by 1/4 inch. The interior has been completely replaced and the seats are original 69 XR7 seats that are still nice and plyable and plump. The door panels were replaced with 70 XR7 panels due to personal preference. The dash is also in perfect condition as is the carpet which has been replaced along with the headliner.
On the exterior, the car is painted 1998 Chrysler Radiant Fire Red and as you can see, really pops. The vinyl roof was stripped and the holes filled. The rear quarters near the bottom were filled with a minimal amount of filler material to take care of a few minor rust incursions. There is NO rust on this car anywhere. The torque boxes and underbody is in great condition, though dirty as this car is driven and meant to be enjoyed, so although we cleaned the underside we didn't repaint or restore it.
The front grill work and rear taillight grillwork was blacked out. Both bumpers were professionally rechromed and look perfect. All the trim work has been polished.
In the engine bay, the motor is a 351 cu in Windsor block, bored to .030 over and has Forged 9.5:1 Speedpro pistons. The heads are Australian 2v heads with the huge 2.19 intake valves. The heads are covered with extremely rare Ford Motorsport Polished Stud girdle valve covers. The heads also sport 1.73:1 Crane Gold roller rockers. The engine runs a Edelbrock RPM camshaft and uses a rare, polished B&A Smith Track Boss 351 single plane intake manifold. Induction is handled via a Edelbrock 750cfm carb. The engine also has a Polished Edelbrock Victor water pump and a chrome 140amp 1-wire alternator to power anything you could possible ever need. The radiator is a fresh 3-core unit which does a fine job of keeping this monster cool in 110degree Texas heat. The ignition is all MSD, including Billet mechanical advance distributor, blaster 2 coil and 6AL ignition box.
The car is originally an A/C car and does have all the A/C guts under the dash, but we did not replace any of the A/C or heating systems on the car and they are not functional.
The dash was custom built with $800 worth of Autometer Pro-Comp Ultra-lite gauges, including an electronic speedometer, tach, water and tranny temp gauges, Air/Fuel monitors with Left/right operation, fuel gauge, voltmeter and oil pressure gauges. Every gauge in the car is fully functional, along with being nicely backlit at night.
There is well over $15000 worth of work and parts gone into this car and a stack of receipts comes with it. The car was built to be a driver and does that incredibly well. It's a mean street performer, and although it hasn't been on a dyno, It's easily a low-mid 13 second car in the 1/4 on street tires. Being a street driven car, it does have a couple minor rock chips.
This car was the Cover car for the 2002 Cougars & Kittens Calendar, as well as the July 2002 car and has also been used in advertisement material appearing in Mustangs and Fords. It's also in the centerfold of the 2003 Cougars & Kittens Calendar!
Any questions can be emailed to [email protected]
MANY MANY MORE PICS AT http://www.logansgarage.com/xr7
