Hello, this is my first set of questions since joining so here goes.
I am wanting to put in a tilt column, which i have now. the problem is that the column i have has the shear pins sheared and is missing the rag joint and vacuum motor/relay. Anyway!
First question: What is the difference in the shafts of tilt and non-tilt columns?
2nd is: Can i use the non-tilt rag joint on a tilt column?
:1zhelp: please
:1zhelp: please
